Message 1 of 2
DIGITAL VOICE
Have a bell in kitchen that used to ring when phone in front room got a call, since going on to digital voice it no longer rings, can it be made to work again.
1 REPLY 1
Message 2 of 2
Re: DIGITAL VOICE
Probably the easiest answer is to get what BT call an "adapter" (which is really a plug in portable phone socket), plug it into a mains outlet in the kitchen, pair it with your hub, and plug a new phone into it. This will then ring when the phone in the front room rings.
