Message 1 of 8
Digital Phone
BT set up my broadband on the 23rd November and also added two digital phones. The engineer who set the network up said the phones would activate with two hours. Despite repeated calls and promises the phones still haven't been activated. BT tell me it's an internal issue with new phone numbers, but that's the only reason I've been given. Anybody else having this problem.
7 REPLIES 7
Message 2 of 8
Re: Digital Phone
When you go to http://192.168.1.254 do you see your phone number on the phone card as shown in red below?
When you click on that it should show the status between your smart hub 2 and the digital voice service as shown below
Message 3 of 8
Re: Digital Phone
Hi no- it just says not configured?
Message 4 of 8
Re: Digital Phone
OK then that shows it is a technical issue specifically with your activation of the digital voice service.
Assuming your on full fibre it maybe worth calling the full fibre team on 0800 587 4787.
If you get nowhere then a moderator maybe able to help.
Message 5 of 8
Re: Digital Phone
Thanks, I’m expecting another call tomorrow, but each time I’m told “ next 48 hours” will try that number .
Message 6 of 8
Re: Digital Phone
Hi @DaveF64, were the team able to help you get this resolved?
Cheers
John
Message 7 of 8
Re: Digital Phone
Hi, yes resolved today. Unhappy that it took two weeks, but it was a guy from the customer care line that chased and chased for. The good thing is he would always promise to ring back and he always did this. He was really pleasant and helpful. Wish I could remember his name, but know that he lived in Accrington. BT compare very favourably to British Gas but their bar is very low. Lesson of the story is never move house. Some of our big utility companies are not fit for purpose.
Message 8 of 8
Re: Digital Phone
Hi @DaveF64, thanks for the update and sorry it took longer than we would hope to fix this for you. It's nice to know that the advisor kept in touch with you as they agreed until they got it resolved.
Cheers
John
