Message 11 of 35
Re: Digital Voice - Distortion / Crackle
I appreciate the help, but if that’s plausible, how come it’s worked fine for 6 months…  that’s my query.
Message 12 of 35
Possibly a deterioration in the performance of the DECT base station in the home hub, or something new, blocking the signal
Message 13 of 35
When you consider the number of analogue to digital conversions taking place over the whole speech path, and the reverse, its a wonder the phone quality is not worse.
Message 14 of 35
I just want it to work fine, like it did before DV and before this happened 3 days ago… I didn’t ask to be migrated…
Anonymous
Not applicable
Message 15 of 35
Surely you can move the base station long enough to test?
Message 16 of 35
It would be interesting to see if a normal wired phone plugged into the DV adapter has the same issue, as that would point to a faulty home hub or a faulty DV adapter.
Unfortunately, Digital Voice is going to be forced on everyone soon, with the closure of the PSTN network.
Message 17 of 35
Just did as you suggested and the phone works fine, so it’s the DV adaptor that’s evidently faulty. Anyone know how I can get a replacement for free? Thanks!
Anonymous
Not applicable
Message 18 of 35
Not necessarily the adapter, could also be the DECT signal from the Hub. Next I'd try the adapter in a different socket, closer to the Hub.
Just a thought but would the recent issue coincide with the switching on of some Christmas lights?
Message 19 of 35
I’ve only got two sockets, one which my fibre (the hub) plugs into and the open reach box and the socket which the DV adaptor plugs into… suggestions?
Message 20 of 35
P.s. no, nothing new has been plugged in or switched on…
