Message 1 of 4
Digital Voice
My Wi-Fi router plugs in to a landline phone socket. When I am moved to Digital Voice, how will that change? Thanks
3 REPLIES 3
Message 2 of 4
Re: Digital Voice
Message 3 of 4
Re: Digital Voice
If it is just the move to digital voice, (and not a move to full fibre), it will not change.
What will change is that your phone will now plug into a phone socket on the back of the Smart Hub 2, which they will send you if you don’t have one already.
Message 4 of 4
Re: Digital Voice
Thank you!
