Message 1 of 9
telephone number for digital voice
Recently moved home and updated to fibre broadband and digital voice. Have plugged in dv adaptor and phone appears to work. My question follows: should BT issue a new number for digital voice as we have moved areas, as it stands I have a phone I can dial out on which won’t take incoming calls. Thanks Andy
8 REPLIES 8
Message 2 of 9
Re: telephone number for digital voice
Message 3 of 9
when moving home did you elect to keep your existing phone number?  with VOIP area codes are no longer important
if you connect phone to socket on back of SH2 can you make and receive calls?
Message 4 of 9
Dial 17070 and it will read back your number.
Message 5 of 9
Thanks for the number but it didn’t read me a number. The message said No CLI detected for this line and gave a couple of test options. No idea what a CLI is ?
Message 6 of 9
Calling line information ( CLI )
If 17070 doesn’t announce the phone number, call your mobile from the DV line and he check what is displayed on the mobile screen…you can set CLI to be withheld, perhaps you have this option set , you can temp override withheld CLI by putting 1470 in front of the number you are calling .
Message 7 of 9
You may have your number withheld so dial 147017070
@iniltous  beat me to it.
Message 8 of 9
Thank you that worked Andy
Message 9 of 9
Yep that worked thanks Andy
