Message 1 of 8
Help for vulnerable elderly person
My mum is 86 , lives alone and has has a repeated faulty BT Landline.
Her nearest relatives are 2 hours away, the most recent report has resulted in a message to say an engineer will be there next week.
 She has a phone linked emergency pendant and has had a stroke.  Her land line is vital to connect her to the outside world.
any idea how to get this fixed sooner and permanently
Tags (1)
7 REPLIES 7
Message 2 of 8
Re: Help for vulnerable elderly person
Is your mother registered here
https://www.bt.com/content/dam/bt/help/including-you/BT_Free_Priority_Fault_Repair_Scheme.pdf
I have asked a mod to see if they can help but being friday next week might be earliest for openreach    mod will post here
Message 3 of 8
@RKD01 I'll send you a private message in a moment so you can send the moderation team your Mums details and we'll be happy to see if anything can be done to speed up the repair.
Neil
Message 4 of 8
Thank you will do that
Message 5 of 8
Thanks was trying to sort out in my lunch break, held for 29 mins then when answered got cut off!
Message 6 of 8
Hi @RKD01, sorry that you got cut off after waiting a half hour for an answer.
Did you reply to @NeilO with the details requested as we'll be happy to help you?
Cheers
John
Message 7 of 8
All sorted. Thank you. The fault was sorted within 2 hours.  X
Message 8 of 8
Thank you for getting back to us @RKD01.
I'm really happy that it's all working now and hope that your Mum is able to use her phone as normal.
If you ever need any help in the future, please, feel free to reach out to us.
DanielS
