Message 1 of 7
Re: Digital Voice adapter won't pair with my Hub
I have just transferred my services over from landline to digital and have been sent a Digital Voice Adapter to enable me to connect my telephone to the service.
I have followed all the instructions on the leaflet a few times and even unplugged it, rebooted my router and started the process over but the adapter is still flashing green and not a solid light.  Searched the forum already for ideas and searched for ideas on the internet.
I am not a technical person and do not have a clue what to try next.
I'd really welcome some advice (in laymans terms) re. what I may be doing incorrectly.
Thank you in advance.  Anne
6 REPLIES 6
Message 2 of 7
Re: Re: Digital Voice adapter won't pair with my Hub
Message 3 of 7
Are you sure Digital Voice has been activated? Does your phone number show in the hub manager or does it say not configured?
Message 4 of 7
Hi It is showing white and inaccessible stating not configured.
Message 5 of 7
Forgot to also mentioned it supposed to have been activated on Friday.
Message 6 of 7
Your adapter wont pair until DV is activated. You need to chase customer services.
0330 1234 150
Message 7 of 7
Fantastic - thank you for this. I thought I may have been doing things incorrectly (although instructions seemed straightforward enough). I'll get on to them.
Much appreciated.
Anne
