Message 1 of 2
Rotary phone
Hi, how do I connect a rotary phone to a VOIP line?
I don't need anything fancy that will handle touchtone menus, just something that will means it can make and receive calls.
I've tried searching online but just end up with a confusing mass of info about tone-to-pulse, DTMF, RJ11 and RJ45 cables / converters!
Can anyone recommend what I need and where I can buy it in the UK
Many thanks
1 REPLY 1
Message 2 of 2
Re: Rotary phone
You need a pulse to tone converter and whatever leads it requires to connect to your phone on the input and the hub BT431 socket on the output.
I have absolutely no idea why you would want to do it though.
