Message 21 of 27
Re: Since Digital Voice Upgrade on 4th Dec - Can't receive any phone calls - contacted BT 4 times!
The local exchange is not involved with your DV connection, so callers that are still connected to the local exchange PSTN, still have to be routed back to your connection via the network.
If they were also on DV, then there would not be an issue. In fact, once everyone is on DV, theoretically, routing issues should go away.
As it is at the moment, there are lots of routes to be sorted out, I can only imagine what the problems are likely to be.
Message 22 of 27
Just to add to what I have said, BT Business customers that have been migrated to Cloud Voice, which is a different VOIP platform, are getting similar issues like missing calls, or no incoming calls. Many complain on the BT Business forum, as you can imagine the money they are losing.
Its usually small businesses that relied on analogue phone lines, as most large organisations moved to VOIP years ago, when the closure of ISDN30, which is was PSTN based, was announced.
Message 23 of 27
Thanks Keith, should of realised that!
Message 24 of 27
The real problem is that people may not realise that some calls are not connecting, they could be important calls.
Message 25 of 27
That's whats worrying me. I was hoping by posting on here one of the moderators would have picked this up. I have seen they have done this on other posts and solved problems for them with the similar issues.
Cheers
Message 26 of 27
The new moderators no longer have account access, so cannot help. All they would do is to refer you to the help pages.
Message 27 of 27
Hi @kevin_hollands,
Welcome to the BT Community
I am really sorry to hear of the ongoing difficulties you have been having with your phone service. As @Keith_Beddoe mentioned we do not have account access to be able to help directly, but I am going to send you a private message to take some details and try and get you some help.
If you can please take a look and respond when you are able.
Alex
