Message 1 of 3
Using BT Premium phones with Smarthub 2
I have a pair of BT Premium cordless phones which worked very well until we switched to fibre and got a Smarthub 2.  When I plug the base unit into the rear of the hub all works well for a few days. Incoming calls ring on both phones as well as the new Digital Voice phone. Then they stop working and only the DV phone works. Occasionally they emit a very loud noise, almost like a siren. If I unplug them from the hub, wait a bit, then plug them back in they work again for a day or two before ceasing to do so.
Any suggestions what may be the cause and can it be overcome?
2 REPLIES 2
Message 2 of 3
Re: Using BT Premium phones with Smarthub 2
Message 3 of 3
Out of interest, have you tried pairing them with the Smart Hub - I know it has it's own BT version of DECT, but might well work with those as they are also BT phones. Worth a try.
