Message 21 of 38
Re: 2nd router
Then there is nothing else you can do except run an Ethernet cable.
If there is already an 8 wire phone cable, you could try terminating an RJ45 at plug each end and see how that performs.
Message 22 of 38
Re: 2nd router
Are you able to run utp (ethernet) cable outside your building? This would be a better option than using powerline adapters.
Message 23 of 38
Re: 2nd router
If there is a phone  extension socket in the attic, simply move the router to there and plug it in the extension socket.
How were you intending to connect a second router?
Message 24 of 38
Re: 2nd router
Ok thanks for the replies.
Can you not use another router and use the same broadband as the main router.
Thank you.
Message 25 of 38
Re: 2nd router
No, you can't.
Message 26 of 38
Re: 2nd router
The main router will stay downstairs as the rest of my family use this.
I thought you could just simply plug in another router into a socket? I’m a person who knows little about all this technical stuff so apologies.
I guess I just thought you could possibly get a second router and use that in my attic and use the Ethernet but perhaps not?
Thank you
Message 27 of 38
Re: 2nd router
No, you cannot do that. You can only connect one router to the phone line. The only options you have are those that have been described previously.
Message 28 of 38
Re: 2nd router
Ok appreciate it.
I also heard you can use an ethernet switch.
Is that true?
Message 29 of 38
Re: 2nd router
It has already been explained. To use an Ethernet switch will require you running an Ethernet cable from the BT hub up to the room that you want your xbox.
Message 30 of 38
Re: 2nd router
Ahh okay cheers
