Message 31 of 38
Re: 2nd router
AS you have been told multiple times, the only solution to your problem will involve running an Ethernet cable.
Message 32 of 38
Re: 2nd router
YES I KNOW THAT YOU HANDSOME MALE
Message 33 of 38
Re: 2nd router
So why do you keep questioning it?
Message 34 of 38
Re: 2nd router
Because im trying to understand it, cheers
Message 35 of 38
Re: 2nd router
It’s an obvious answer that you need an ethernet but its not that easy for some people like me. I cannot as the router is so far away from me
Message 36 of 38
Re: 2nd router
From all the previous posts if you cannot use an ethernet cable for the connection then you cannot achieve what you want in attic
Message 37 of 38
Re: 2nd router
Unfortunately I cannot mark it as an accepted solution as there is no solution that I have apart from have an extra long ethernet cable that goes from my 1st floor to the 3rd floor or have an ethernet cable that is outside the building. So, I will need to look for options elsewhere
Message 38 of 38
Re: 2nd router
Did you read messages 21 and 23?
