Message 11 of 15
Re: BT Full fiber 900MBsw
You appear to be using the smart WiFi where hub selects the WiFi channel so if you get a WiFi analyser on phone you can check the channels in use near you then manually select your hub WiFi channels which are free or less congested and see if the helps
Message 12 of 15
Do you recommend a WiFi analyser app
Message 13 of 15
Any will do as they all do the same job. I use WiFi analyzer by farproc on Android
Message 14 of 15
@Jack97wrote:
Checked the network for the channels and everything seems alright.
Also tried changing modes, thinking of asking for another new SH2 Maybe it'll fix things.
Just to be clear you did switch the 5g channel off? And then try selecting a channel on 2.4g?
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings icon. If someone answers your question correctly please let other members know by clicking on ’Mark as Accepted solution’
Message 15 of 15
Update, got a new hub and nothing has changed at all. Still the same issues. I had a BT home tech come over and he's also very confused to why its saying the WiFi signal is poor, he suggested I get a new hub ( Hence the new hub update) here is a the photo
