Message 11 of 37
Re: BT Halo HUB-Device Speed Difference
Any chance i could "ask" for the newer type from BT, anyone got one from BT?
Message 12 of 37
5 ghZ
Anonymous
Not applicable
Message 13 of 37
Loads on e bay....literally plug and play
Message 14 of 37
You won't get a WiFi 6 hub from BT - all they supply is the Smarthub 2 which is WiFi 5.
But you can buy an EE WiFi 6 or WiFi 7 hub - just Google it and several surprisingly cheap offers come up. And it's been established that EE hubs work seamlessly with BT broadband.
However, and I may be wrong, but I don't think you'll ever get 900Mbps via WiFi. That needs a Cat5e or Cat6 ethernet cable between the device and the hub.
Message 15 of 37
See my WiFi 5 screenshot
Message 16 of 37
yeah i am getting that speed when connected by cable
Message 17 of 37
or i could cxd BT and go with EE, i am still within the 14 day cooling off period
Message 18 of 37
i did, but i couldn't workout the meaning, not that tech savvy, sorry
Message 19 of 37
your right, on eBay about £40
Anonymous
Not applicable
Message 20 of 37
I have BT 500mbps...on the BT router never managed more then 120 mbps over wifi. I invested in the EE wifi 6 router for £35 unopened.
Now regularly get 510mbps on wifi.
Do you need 900mbps though?
You'll find in the real world even 500mbps is overkill. Plus it's obviously a lot cheaper.
