Message 11 of 32
Re: BT land line not working
So I have no idea what to do now!!
Message 12 of 32
Re: BT Smart Hub 2
when you say Ask if there is an option to switch from FTTC to FTTP what do you mean?  Full fibre is not available at my property at the moment!
Message 13 of 32
Re: BT Smart Hub 2
@andreaferns120472
You’ve just answered the question yourself. If there’s no FTTP available then you don’t need to ask.
Call BT and complain if you’re not getting the level of service you are paying for. If the problem is with the connection from the street, they are the only people who can deal with it. Sadly, it’s very much a case of haranguing BT until they can be bothered to fix the problem.
Message 14 of 32
@andreaferns120472
With respect, you’ve already been advised what to do in the other thread you created relating to your internet connection issues. You clearly know how to contact BT as you’ve already been doing so.
No one here can magically make your issues go away. Maybe a Moderator might pop by with some advice.
Message 15 of 32
Re: BT Smart Hub 2
So apparently you are on FTTC (fibre to the cabinet ) and have had a BT ‘tech’ , who are not ‘skilled’ in the vagaries of the Openreach network, giving your home setup (what they are trained in ) a clean bill of health , and saying the fault is  external , and an Openreach engineer doing some preventative measures (like changing the port in the fibre cabinet ) but saying the external network is fine , at this point you may say someone is wrong , BT and  Openreach can’t both be correct .
There is a problem , search ‘Rein and Shine’ broadband faults if you want , but basically Repetitive Electrical Impulse Noise , and Single High Impulse Noise Event (or words to that effect ) are basically caused by faulty electrical devices, faults that don’t necessarily stop the device working  , for example, a central heating/water pump , when they switch on , they create a large amount of electrical ‘noise’ that needs to be suppressed, if that suppression fails the pump still works but the electrical impulse causes your broadband router to lose synchronisation , it regains sync ( but you notice the outage ) and the next time your heating /water pump switches off and on , the same thing happens …..this isn’t just central heating pumps , cheap Chinese Xmas tree lights , and many other household appliances can cause this , in fact it isn’t necessarily in your home , it  could be a neighbour’s home , there was a famous case where some person in a village had an old TV , when they switched it on , the electrical noise was such an intense ‘noise’ that pretty much the entire village broadband dropped out , this ‘noise’ isn’t audible, you can’t hear it .
Obviously I can’t say it’s this , but it can’t be discounted either, and if it is something like this it’s not really your providers ‘fault’ and takes considerable effort to locate .
Message 16 of 32
Re: BT Smart Hub 2
@iniltous
With respect to the OP, you’re flogging a dead horse, they don’t even know what most of the acronyms mean relating to the equipment that supplies the service they’re getting.
On top of that, there’s now two threads running from the same individual relating ultimately to the same issues albeit split between internet and landline problems.
Message 17 of 32
Re: BT Smart Hub 2
Thanks so much for detailed reply! I don't think this is problem as this started around 3 weeks ago, and I have made no changes to any of my electrical appliances apart from the last few days I have had my heating on permanently as its been so cold.
Message 18 of 32
Re: BT Smart Hub 2
Unfortunately intermittent faults are extremely difficult to track down and resolve. In the good old days of the GPO, infinite time could be spent in getting to the bottom of a difficult fault. Alas this is no longer the case as folks aren't prepared to pay for such a gold plated service and costs are reduced to keep prices down resulting in a workforce that is not allowed to expend the time necessary to trace such a fault. Costly well trained  experienced engineers are also replaced by inexperienced cheaper staff.
Such is the way of the world today.
Message 19 of 32
Re: BT Smart Hub 2
As explained, it isn’t necessarily anything within your property when it comes to this type of problem and just because you have your heating on constantly doesn’t mean the pump (for example) isn’t switching on and off depending on demand etc , but as stated , given the supposed lack of any hard issue elsewhere, it’s a possibility.
As far as I know, when OR engineers close a fault they supposedly capture and store the line test results, if there were a line problem (as the BT tech suggests but the OR engineer states doesn’t agree with ) then a satisfactory line test result wouldn’t be available so the fault report would remain open as a requirement is a satisfactory test result.
For all that , if the line still drops , report it again , or more accurately reopen the initial report , but as you have another post on here about your telephony not working clearly there is a hard fault somewhere , and they are much easier to track down and repair than nebulous , intermittent faults .
Message 20 of 32
Re: BT Smart Hub 2
A line test result is pointless in the context of an intermittent fault.
