Message 1 of 8
Garden wifi
I've searched other posts as I know this is a common issue.
I have just had full fibre & smart hub 2 installed.
Previously I had bt hub 6 in house and bt hub5 set up as slave/access point in garden room using a powerline adapter. (Although on different consumer units it worked ok)
Now with SH2 the slave will not work. I can't connect or when it does there is no Internet.
Garden room is approx 15 metres from back of house and SH2  is at front.
Ideally I'd rather not run a cable so looking at the best type of extenders and I've not really used any...any help appreciated.
7 REPLIES 7
Message 2 of 8
Re: Garden wifi
I have a similar setup the Summerhouse being 20 metres away from the back and the Smart hub 2 at the front of the house. I have 2 complete Wi-Fi discs the Black one from BT. One disc is upstairs at the front of the house the other disc is in the Summerhouse and I Have a great Signal in the house and garden.
Message 3 of 8
Re: Garden wifi
Did you set up the slave with a fixed ip? You may need to change the subnet so that it matches the SH2.
Message 4 of 8
Re: Garden wifi
@spile Hi, it was set up following an older thread. I think the ip address of the slave hub is changed at the last block of numbers to 20 or something. Dhcp and firewall is off.
Worked OK until I changed the main hub and service 🙄
I'll check the subnet though thanks.
Message 5 of 8
Re: Garden wifi
If powerline is working out there, why not just get a set of powerlines where the remote unit has built in Wi-Fi?
The tp-link ones are cheap at under £40
Message 6 of 8
Re: Garden wifi
@dave44 since changing hub and service the powerline isn't working in garden.
Message 7 of 8
Re: Garden wifi
@Hildener sorted now thanks. Got the tp link deco m4 mesh set.
Message 8 of 8
Re: Garden wifi
Glad you got it sorted. Good luck with the mesh system.
