Message 1 of 9
Is this a modem in my house?
Hi,
I have a BT Home Hub2 + a white box on the wall in my garage.
Can anyone confirm if this is a modem or not?
I am asking because I have a couple of Deco M5 dics and I'd like to run them in router mode, but conscious that the BT HH2 cannot be run in "Modem mode", so I'm wondering if I can rid myself of the BT HH2 and just connect the Deco straight into this white box thing (hoping it's a modem).
Thanks and excuse my ignorance.
Z
Tags (1)
8 REPLIES 8
Message 2 of 9
Re: Is this a modem in my house?
Yes, it is and yes, you can unless you have Digital Voice phone service, in which case that will only work with the SH2
Message 3 of 9
Thanks for the quick reply.
Do you know how I would know if I have a Digital Voice phone service? We have a home telephone..
Message 4 of 9
Where is it connected to?
Digital voice uses DECT (cordless) technology to connect to the base station incorporated in the hub.
Message 5 of 9
The phone is connected via the very old cable, so guess I'm OK 🙂
Message 6 of 9
If it is connected to the ONT (modem) it will be legacy FVA (Fibre Voice Access) which will be converted to DV at some point.
Message 7 of 9
Is your BT hub actually connected to that ONT? The reason I ask is that the Port1 light is not lit and I would expect it to be.
Message 8 of 9
Hi,
Eagle eyes!
It is connected and we have Internet in the house so I assume its working OK?
I guess if it wasn't plugged in, we wouldnt have any Internet right?
Message 9 of 9
Not necessarily. You could be using a DSL connection where the hub is plugged into a phone socket rather than into this ONT.
It might be worth posting a photo of the cables going into the rear of the hub
