Message 1 of 31
New hub
Connected my new bt hub earlier,  followed the instructions to the letter, says connected but no internet, and the hub is constantly flashing red/pink. Triple checked all connections etc....still nothing.
Contacted bt who did tests to no avail. Now waiting for an engineer to come next tuesday.
Tried to reconect my old hub, but now that doesn't work....same problem with constant red light...Done factory resets, but still won't connect.....whotta complete shambeles this changeover is proving tp be. Thankfully my phone allows me internet access to the internet to post this!
30 REPLIES 30
Message 2 of 31
Re: New hub
What are you upgrading to?
If you were on Part-Fibre (FTTC/VDSL) and have upgraded to Full-Fibre (FTTP) you need to connect the hub to the ONT via yellow LAN port 4, not the old DSL port.
Message 3 of 31
Re: New hub
Nope! not on any fibre
Message 4 of 31
Re: New hub
so what connection do you have - adsl/vdsl just copper or FTTC (fibre to cab and copper to home) or FTTP (fibre to home)?
why did BT send you a new hub? SH2?
Message 5 of 31
Re: New hub
As far as iknow, just copper....almost certainly.
Message 6 of 31
Re: New hub
So, is this the upgrade to Digital Voice (DV) then?
If so, the hub connections should be the same as your old hub with the exception that the phone now plugs into a socket on the back of the hub.  They should send you a text to say when the change has gone through.  If you then reboot the hub it should pick up the new settings and show your phone number of the management page of the hub.
Message 7 of 31
Re: New hub
I'll wait for the engineer. I have no interest in all these tech solutions mosy of the terminology goes right over my head! etc.
Thanks for your time and answers
Message 8 of 31
Re: New hub
Fair enough...but why post on here in the first place then?
Message 9 of 31
Re: New hub
@gormsgast
non technical question - why did BT send you a new hub SH2?
Message 10 of 31
Re: New hub
Because most replies are quoting god knows what technical terms that many, including myself dont get... ok Mr know all?!!
