Message 1 of 10
Openreach Modem
Just visited my new build it has a openreach Modem box on the wall,how do you set up the internet meaning do it have to plug my BT router in or is it just a case of ringing BT and giving them the serial number on the front of the openreach Modem when I move in.
9 REPLIES 9
Message 2 of 10
Re: Openreach Modem
are you currently a BT Retail customer for Broadband?  if so you just connect hub to ONT and then phone BT.  are you using BT home move if existing customer?
Message 3 of 10
Re: Openreach Modem
Hello
Thanks for the reply much appreciated,I'm currently a BT retail customer and have the BT halo 1 with fibre package so your saying I plug in my existing router and ring BT on the day I move in?
Message 4 of 10
Re: Openreach Modem
Deleted by poster
Message 5 of 10
Re: Openreach Modem
Have you followed the BT Home Move process?
You would need a BT Smart Hub 2, which will be supplied by BT, provided of course you have an order in progress. The service has to be activated on a agreed future date, it cannot just be done on the day, by request.
Message 6 of 10
Re: Openreach Modem
I'm moving at the end of the month, then I will follow the BT move process.
Yes I've got the BT smart hub 2 router
Thanks again for your help
Message 7 of 10
Re: Openreach Modem
@Biglad
You need to start the home move process now, otherwise your connection will be delayed.
https://www.bt.com/manage/moving-home/
Message 8 of 10
Re: Openreach Modem
Thanks for information but it's a new build and therefore the postcode and address aren't yet on the system to let BT do their end of the move.
Message 9 of 10
Re: Openreach Modem
Hi @Biglad, welcome to the forum and thanks for your posts.
If you have a definite move date, then call in and speak with the FTTP team as they'll be able to check your address and advise you further about getting connected. As this is a new build and not listed yet they'll be best placed to help you.
Cheers
John
Message 10 of 10
Re: Openreach Modem
Thanks John
