Message 11 of 16
Re: Sky Q tv installation disconnecting ring door camera
Thanks, Ill give this a go
What i have noticed is that when 5ghz is turned on i am able to connect to 2.4ghz and the ring says it is connected on the admin page momentary. When 5ghz is turned off i am unable to connect to the network at all... is this any clue to what is going on?
Message 12 of 16
It sounds as though the device you are using only has 5Ghz capability and doesn't operate on the 2.4Ghz band.
Message 13 of 16
according to Ring spec the outdoor cam plus is dual band 2.4 and 5ghz   maybe this is newer versions
https://ring.com/gb/en/support/products/cameras/outdoor-cam-plus?page=1
Message 14 of 16
Message 15 of 16
That is only single band.
Message 16 of 16
Download a wifi analyser app on your phone. That will show if the hub is transmitting a 2.4Ghz signal
