Message 1 of 8
Smart Hub Ethernet Connection
Hi, after a household power outage recently, when all 4 worked before, now its only gig ethernet port 4 on Smart Hub type B that connects anything.
Does anyone have any ideas how other 3 may regain connectivity?
7 REPLIES 7
Message 2 of 8
Re: Smart Hub Ethernet Connection
Have you tried a factory reset of hub by pressing the recessed button back and holding 20\30 seconds until hub lights flash and see if that fixes it
Message 3 of 8
Have tried that without success, thanks anyway
Message 4 of 8
Hi @ChrisMacL I'd recommend getting in touch with the broadband faults team on this link and they'll sort you a replacement.
Neil
Message 5 of 8
Much appreciated!
Message 6 of 8
@ChrisMacL post back and let us know how you get on.
Neil
Message 7 of 8
@ChrisMacL
One possibility, although remote, is surge damage when your power supply was reconnected.
Message 8 of 8
Hello, after a unrelated broadband line problem that was discovered while telling BT about this, a new Smart Hub has been delivered and all connections working fine on this one.
