Message 21 of 25
Re: openreach master socket port shape is wrong - can't verify BT ID
Rebooted my PC and it worked! thank you so much everyone! this is really week-saving. Thank you thank you thank you
Message 22 of 25
You're welcome.
Sorry we couldn't get there a bit sooner.  I should have thought of the phone socket being a single.  The more modern ones have the two ports built-in and don't need the microfilter.
Message 23 of 25
Not a question of modern or not, the NTE 5c is the most up to date version of NTE but still comes in 2 varieties of faceplate.
Must admit I assumed it would be the filtered faceplate version the OP had.
Message 24 of 25
@licquorice   True - I was just trying to keep things simple.
Message 25 of 25
Not at all, I was gearing up to run around like this all weekend so I’m really relieved. Kudos all around @WSH @Anonymous @licquorice
