Message 1 of 5
third party router
As BT Smart Hub2 has limited  features and isn't really configurable I've decided to change it but for some reason I can't get internet access with a different router. I have a mini pc with a firewall/router pfsense installed and directly connected to ONT but I have no internet and the situation is the same with omada tplink router.  I choose PPPoE connection and entered BT credentials [email protected] and password BT.  I can manage to establish a connection and gateway but I have no luck with the internet. Magically everything works with BT SH2. I have attached all screenshots from all my routers including BT SH2. Thanks for any help.
4 REPLIES 4
Message 2 of 5
Re: third party router
The WAN addresses are not internet addresses.  It suggests it not managing to log into BT's servers and get valid WAN IPs!  *At a guess are you using a VLAN on the WAN interface, you don't need to with BT FTTP!
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
Message 3 of 5
You appear to have entered a username of [email protected] instead of [email protected]
Message 4 of 5
It's working now !!! What a embarrassing mistake I made I don't how I miss that. Thank you very much.
Message 5 of 5
If you are using pfSense you can increase the WAN MTU to 1500 as BT support baby jumbo frames.  For IPv6 you will need the following settings:
IPv6 PD /56
Only request an IPv6 prefix
PPPoE monitoring IP 1.1.1.1
____________________________________________
BT FTTP 500/75 + pfSense + 4 x UniFi Wifi 6 Pro
