Message 11 of 34
Re: Watching TNT Sports via Discovery+ app
Thank you very much for the password reset advice. This has now worked with my D+ account linked to my BT subscription. I hope the app has the same functionality as the BT Sport app had.
Message 12 of 34
I too am having the issue that I cannot activate discovery plus with my bt tv subscription. I get no activate button on my bt homepage.
I suspect it may be because I already have discovery plus on sky but that is without the sport channels, so I need to activate it via my bt subscription.
Has  anyone managed to do this?
Surely BT should have solved this by now?
Thanks  Jen T
Message 13 of 34
It's not related to already having Discovery+ from Sky.
If you only just added your TNT Sports subscription then give it a few hours and try again. If it's already been a few hours since the service was activated then please check further in MyBT (the web site - not the app). Check in Your products then the TV or Sport sections within there. If you definitely don't see it anywhere then send me an email at [email protected] with your BT ID and BT account number, and I'll get your account checked.
Message 14 of 34
My experience is that I have D+ via Sky and TNT Sports from BT and activated the link in the MyBT app.  I can now see the TNT Sports channels on the apps on my iPad and Apple TV 4K, but not on the D+ app on Sky Q.
 Also, I get HD/UHD(Ultimate) without  having the TNT HD/UHD pack.  The D+ subscriptions page says that Sky manages my subscription.
Message 15 of 34
Thank you Darrendev for asking BT to sort this for me. They have sent me a link to use to activate discovery plus but it just takes you to a blank screen so not much further forward!
Message 16 of 34
Is that via email or text @JenT21? If email, could you please forward the email to me at [email protected]
The fault with your account was found (a missing entry on one of our systems) and it was corrected a little over an hour ago. I'm guessing that's what caused an automated message to be sent to you. You should now see the "activate discovery+" tile in MyBT.
Message 17 of 34
Unfortunately now I can’t even log into my bt. It just hangs and hangs and then reopens the log in page. I think there must still be something wrong.
Hopefully it will get fixed eventually!
jen
Message 18 of 34
That's a strange one - I can't think of anything on the account that could cause that. Could you please launch an incognito/ private browsing window and try from there? That should confirm that the issue isn't related to any cookies or cache for the site.
Message 19 of 34
Hi
I can now log in okay again, don’t know what the previous problem was all about but still no activate discovery plus tile?
Jen
Message 20 of 34
OK, sorry to hear that - I've added a note to your ticket to investigate further,
