Message 31 of 47
Re: BT TV addons bug and order stays open
Update: the error code is my work IP blacklisted, i've logged in on 4G ok.
Preview of my next bill does not include the discount, that might need fixing.
Message 32 of 47
You're correct - your work IP address comes from an internet hosting company. They're the most common source of bots attempting to hack accounts, so they're blocked from logging in (that's one of many reasons why TS-0003 can be shown).
What discount are you referring to? Is this a recent sign-up promotion? I'm sure the guys will know when I add a note to say to check it, but it'd be better if I could be specific if possible.
Message 33 of 47
the original offer I signed up for was 100mb broadband plus NOWTV entertainment for  £19.99 for 12 months then £29.99 for the second year.
For example, my first bill from June was
Broadband £29.99
Entertainment discount -£10.00
Netflix upgrade to Standard x 2 months (May and June) £8.00
HD and 4K upgrade £6.00
total £33.99
When I added the VIP package originally (the order that stuck) it went on my bill preview for next month as £66.00 + £29.99 broadband = £95.99 which is what I was expecting.
After todays changes it's showing as £76.00 + £29.99
It's not clear from my billing preview what the start date is I'll be charged for either, but I assume that will show as today when it's all done. (i still can't see the order details at the moment, but all my services are working fine)
Message 34 of 47
Perfect - thanks for all the detail. I've added it to the ticket to make sure it's sorted before the fault is closed.
Your start date will be from order completion - today.
Message 35 of 47
All good then I think, you can mark this as solved.
@DarrenDev  Thanks very much for all your efforts over the last few days, it's much appreciated.
It's easy to complain when things go wrong, but you've been really helpful and all round excellent getting this sorted for me. Thanks again.
Message 36 of 47
@DarrenDev
do you know if this has been closed out now?
I still have no discount showing on my TV package, and to top things off, Netflix took a payment of £10.99 off my card in the 1 hour window between the stuck package being cancelled, and the new package being opened by your internal team.
the above might be reflected on my next bill, but I'm not confident.
Message 37 of 47
The ticket is still open, waiting for your discounts to be applied - I've added your comments to make sure you're credited as necessary.
Message 38 of 47
@DarrenDev
I've just had my September bill.
I've been billed from 22md of August, not the 5th September, and there is also no Entertainment discount.
Message 39 of 47
@DarrenDev
Please can you confirm what is happening?
Message 40 of 47
With everything happening on discovery+ and a few people being on leave, the queue is taking a little time to process. I chased yours on Friday though - it should all be sorted before your next bill.
