Message 1 of 11
Netflix
Hi I'd be grateful if someone will confirm that I've understood correctly, that only the £10.99 Netflix membership is avialable as an add-on to BT TV?
If so, and I sign up directly with Netflix for the £4.99 package with adverts, will that work with my BT TV box?
Thanks in advance
10 REPLIES 10
Message 2 of 11
Re: Netflix
Hi, @mosska
Netflix is included within the package. Which package do you have?
Stewart
Message 3 of 11
Re: Netflix
Hi Stewart, thanks for the reply.
I only pay £29.74 per month which includes £18.30 for TNT sport and £11.44 for an extra mini box.
Also have broadband and a landline.
I phoned a while back and was advised that to include Netflix it'd be an extra £10.99 per month.
I just wondered if I arrange the cheaper Netfix direct with them at £4.99 (with ads) would that work with the BT box or can I only arrange via BT
Message 4 of 11
Re: Netflix
You can get Netflix from BT directly or via Netflix, they both work on the Youview box exactly the same.
Message 5 of 11
Re: Netflix
Thank you much appreciated
Message 6 of 11
Re: Netflix
Unless you want to change your BT TV package than I would get Netflix direct from Netflix.
All companies seem to offer Netflix now as part of a package and dont offer a choice of paying direct to Netflix.
Message 7 of 11
Re: Netflix
Thanks, I appreciate that 🙂
Message 8 of 11
Re: Netflix
Except that the cheaper, advert-supported £4.99 per month Netflix subscription does not work on the BT box (something to do with the app cannot be upgraded sufficiently) so you can only use the £10.99 subscription
Message 9 of 11
Re: Netflix
Thank you, that is helpful
Message 10 of 11
Re: Netflix
I believe that Netflix Standard with adverts  has recently (quietly) been added to the available addons   to the  EE TV Sport or Big  Sport packs.  (£4.99 monthly on 30 day rolling contract) Sources the respective Price Guides from EE and BT).
