Message 1 of 5
BT pole marked Decayed stopping fibre installation
Hi,
My house is served by a pole marked D, the engineer says it means Decayed and is up for replacement. It has been like this since 2 years. Problem is Community Fibre is refusing to install the broadband on this.
Is there anyway this pole can be fixed/replaced by BT?
thanks
4 REPLIES 4
Message 2 of 5
Re: BT pole marked Decayed stopping fibre installation
@saupraka
Welcome to this user forum for BT Retail phone and broadband customers.
Its Openreach not BT Retail that look after the external network.
You could ask them.
https://www.openreach.com/help-and-support/when-to-get-in-touch-with-openreach
Message 3 of 5
Hi @saupraka and welcome to our community.
@Keith_Beddoe advice is sound. Your best bet would be to contact Openreach via the link he's posted and they should be able to help.
Cheers
David
Message 4 of 5
A D Pole doesn’t necessarily mean it has Decay.
It could be marked D for a variety of different reasons, Shallow Depth, Safe Climb Obstruction, etc.
Unless it is in Imminent Danger of Collapse and accessible via a Hoist and or Scaffolding then they’ll be in no hurry to replace it.
Message 5 of 5
The post is around three months old and the OP was a Community Fibre customer , they are unlikely to be returning to see any new reply’s
