Message 31 of 36
Re: BT TV Box Pro - Connecting via Wi-Fi is not possible
sent you a pm as you requested with the details, still waiting for a response...
Message 32 of 36
Hi @pc001, sorry that you've not been contacted back yet about this. I'll chase this up with the team and you should be contacted within the next 24hrs.
Cheers
John
Message 33 of 36
I’m also experiencing the same problem. Could someone from BT please get in touch
Message 34 of 36
Hi @Absey sorry about that, are you getting any error messages and have you followed these steps to set it up?
Neil
Message 35 of 36
Thank you yes I have. I did get it connected eventually, see how it goes for a few weeks.
Message 36 of 36
Hi NeilO,
I have recently got a new BT TV Pro box and I am unable to connect this to my router via wireless, I have tried the WPS button on the router and this just flashes blue and doesn't do anything and also I have tried to connect using a manual scan and when I type in my password this doesn't work either. are you able to advise.
Simon
Tags (1)
