Message 51 of 406
Re: Important updates to your virus and password protection
Seems fixed
1- wait for normal update of BT VIRUS Protect on Google Play. Do not run App!
2- go to MYBT app which you will try to sign in as normal - it will say no account registered with this. Wait it will ask you to sign in use BT sign in & BT password, set up pin entry, will run
First set up fingerprint access then select
you products / select Broadband / swipe down to Manage Security Settings / down to BT Virus Protect /manage will logout after you enter BT /password.
Only now go to app may be installed on home page or in app drawer. Blue Shield BT Virus..
Enter BT email / password.
you should be off, but check configuration (can't remember but I think after allowing text messages to be read (and checked for spam) had to hit go back & then continue set up, check configuration. It runs smoothly & obviously after this.
Phew, now got Pixel 5, Pixel 6 Pro & Samsung Tab 6 added, still to do my wife's iPhone & ipad.
Message 52 of 406
Norton on Android
Problem installing Norton on Amazon Fire Android tablet.
1 Uninstalled BT anti virus (Mcafee).
2 Downloaded and installed BT Norton
3 App icon show Mcafee!
4 Opened app
5 Selected “Get your BT Activation Code
6 Entered BT ID and P/W
7 Trouble connecting to network
There is nothing wrong with the network
Not sure where to go from here.
Has anyone else tried to put BT Norton on Android?
Message 53 of 406
Hi @goldrickm, we'll keep the thread updated so all users will be notified of any updates.
Cheers
John
Message 54 of 406
Re: Norton on Android,
I tried to put Norton on my Andriod 11 phone, had same problem as laptop, error message
Message 55 of 406
see my entry above under kensim, note wait for update from Google Play first.
Message 56 of 406
at - you products / select Broadband / swipe down to Manage Security Settings / down to BT Virus Protect /manage will logout after you enter BT /password. I login then get sorry technical issue
Message 57 of 406
Just seems to reinstall the BT MacAfee anti virus and and when I go to get activation code get same error message
Message 58 of 406
Exactly the same issue
Message 59 of 406
you need to wait for update rolled out to Google Play. Then resign into MYBT THEN run BT virus app(Norton)
Message 60 of 406
Kicked me out of macaffee and won't let me back in. No now had to download avg
