Message 271 of 406
Re: Can't update from Sophos to Norton
Might well be a self help forum and thank you for your help
But BT like Sky, O2 in fact almost every Tech company expect the user to always sort issues themselves because it means that they do not have to spend money on technical support; it therefore helps their bottom line.
This is obviously a common problem (particularly where there are already pages of comments); this was not the only thread mentioning the issue. So putting a note along with the Important Updates ..... would make sense
But once again thank you
Message 272 of 406
Hi
Within MyBt
Login to MyBt
Click on Your Security, etc...
Then the error message appears
Message 273 of 406
Thanks, @huwpne2022 Do you have more than one BT account associated to your BT ID? If you do have you chosen the correct one from the drop-down?
Neil
Message 274 of 406
I get the same server error day after day, it is from my when I try to manage Virus Protection on Laptop, PC and via the Virus Protection app on my Android phone, I have selected the correct ID, as I have 2 accounts listed only 1 has broadband, and checked the ID is an email address that is the same as my BT ID this is very frustrating that BT knows about issues but is not pro actively sorting out and just leaving user (customers) to troll through a forum and useless help pages.
Something went wrong - Official Site _ Norton Account Sign In & Set Up_Page_1.jpg
Message 275 of 406
Cheers, think my issue might just have been a server issue, seems to be playing ball now
Message 276 of 406
Hi Neil
Mine might just have been some sort of connect issue, just tried again in Firefox and it has downloaded the Setup file
Many thanks for your help
Message 277 of 406
@huwpne2022 That's great,  I'm glad it worked for you and sorry about the issues experienced.
@colin1501 I'm sorry we'll need to raise that with the Virus protect team for further investigation. I'll send you a private message in a moment so you can get in touch.
Neil
Message 278 of 406
Re: Can't update from McAfee to Norton
i have the same problem. its rubbish roll out
Message 279 of 406
I left it alone and went back later; it then worked - wonder if it’s a server load issue…
Message 280 of 406
i have been trying for 4 days. Always get "server error try again".
Think i will go to a different internet provider. Bt isnt much good.
