Message 11 of 46
Re: Noise margin change and speed loss
Thanks for your reply,
O yes it was 18 months ago! haha
I did the quiet line test and cant hear anything. I only rebooted my router once the speed had dropped to 54.999 to see if it was the router playing up, I wont reboot it again. I was told last time that its best to just leave it to see if my original speed came back, it didn't. So does it look like im stuck with 54.99 now? Also isn't a 7.5 noise margin high? I remember when i was like 3.5 a few years ago.
Message 12 of 46
54.999 Mbps - This stat looks locked at that speed. I am on fibre 2 but do you think ive been given fibre 1 speed for some reason? Can bt please run a line test. I'm quite anoyed about losing so much speed.
Message 13 of 46
you you had been moved to fibre 1 then up speed would be restricted to 10mb and it is at 12mb
have you tried using the test socket with a filter to see if that helps your connection and post new stats - especially attainable speed which is currently only 59mb
Message 14 of 46
I will try the test socket now, Could a mod on here do a DLM reset would that help?
Message 15 of 46
from your stats there is nothing to suggest a DLM reset is needed - normally after a fault has been found with engineer visit
Message 16 of 46
These stats are plugged into the test socket, the stats suggest there was a firmware update last night, could this effect it? Is there any way for a mod to do a line test for me at least?
Message 17 of 46
Can a mod not reset it so my line target like 3.5?
Message 18 of 46
A DLM reset won't give you a target of 3.5 and cannot be forced.
Message 19 of 46
Ok, but does whats happened to my stats suggest theres a fault on my line somewhere. Is a 7.5 noise margin normal?
Message 20 of 46
If you think there is a fault on your line then report it to CS 150 and get engineer visit
