Message 11 of 68
Re: Solid Broadband Connection but no Internet/Traffic
Manually setting the DNS settings won't effect anything if there is two DHCP servers on the network as they can cause IP address conflicts.
Also the OP has indicated they do have two BT smarthubs 😉
Message 12 of 68
The OP has 2 hubs but they are not both connected.
Message 13 of 68
As yet the OP has not confirmed that, or confirmed their network configuration. Doing both of these would help
Message 14 of 68
Just one BT Smart Hub 2 connected
I received two others last week which were connected in turn but made no difference so original Smart Hub 2 is now connected
Message 15 of 68
What other devices are you using on your network and also have you tried manually setting the network settings instead of using DCHP?
Message 16 of 68
Devices usually connected :
Macbook
Mobile Phone
Ring Doorbell and Ring Cam
Xbox
Sonos Speakers
Sky Q box
Nest Thermostat
None of the above were added recently, all worked for years/months until a week ago when internet access stopped.
Thanks for inputs so far, but have just had contact from the Mods so will wait to see what they say before I make any changes to settings
but still very interested in what anyone might think the problem is
Message 17 of 68
I would be extremely surprised if it is anything with your home network. I suspect it will be a problem in the BT infrastructure.
Message 18 of 68
Quick update..
BT Openreach Engineer has just been and we might be getting somewhere as he has seen something similar in the past
He has spoken to someone in BT who thinks that following a system update, my broadband username does not match the one shown for the Smart Hub 2, namely the standard:  [email protected]
Might have to wait up to 24hrs for a fix but hopefully they will escalate
Message 19 of 68
Do you have a solid blue light on the smart hub?
Message 20 of 68
Yep, solid blue
