Message 21 of 68
Re: Solid Broadband Connection but no Internet/Traffic
Then authentication is not the issue. The BT engineer should have picked up on that when they spoke to whoever they spoke to
Message 22 of 68
@Checked2013Which BT engineer would that be? They don't have any.
Message 23 of 68
Most likely one of BT’s ‘Home Tech Experts’ aka a Qube Socket Jockey whose technical expertise is limited to plugging in another Hub and if that doesn’t work referring it to Openreach.
Message 24 of 68
As I said in my previous post, BT Openreach engineer visit was yesterday and he called the BT (ISP) fault team
Message 25 of 68
It’s just Openreach, not BT Openreach, they were never actually called that.
As BT now use their own in house Engineers, called Home Tech Experts, who are actually (self) employed by Qube Communications but people call them ‘BT Engineers’ now.
This is where a lot of confusion comes in when people post or here saying ‘BT Engineers’ as no ones ever sure if they’re talking about BT, aka Qube Engineers or Openreach Engineers.
Message 26 of 68
OK, for clarity
Openreach Engineer visited yesterday,
Message 27 of 68
I just hope that you can get a resolution to your issue soon
Message 28 of 68
Latest is that Openreach network has been checked and is OK so now looking at BT Retail set up
Message 29 of 68
Update, Day 13
Still no internet
Mod is working on this but so far no progress
I've been googling like mad, and was wondering if there might be a problem with the standard broadband username not working/authenticating for me for whatever reason? I have tried changing it to [email protected] but no luck, also my [email protected].
I know, clutching at straws...
Product code:Smart Hub 2
Serial number:+091298+1903007694
Firmware version:v0.26.03.01286-BT
Firmware updated:Thu Apr 15 01:34:04 2021
Board version:R01
GUI version:1.74 12_11_2020
DSL uptime:0 days,20 Hours37 Mins10 Secs
Data rate:16.933 Mbps / 57.971 Mbps
Maximum data rate:16.930 Mbps / 76.302 Mbps
Full Fibre (FTTP) Mode:Off
Noise margin:6.0 / 5.9
Line attenuation:5.4 / 17.4
Signal attenuation:5.4 / 16.6
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:37.6 MB Uploaded / 4.4 MB Downloaded
Broadband username:[email protected]
Message 30 of 68
It should be left on the default username and password. You can always do a factory reset if you need to get back to that setting.
Looking at your line stats shows there is nothing wrong with your Internet connection and even more so that it's showing data sent and received, which does push me more towards it's a device on your local network that is causing the issue.
