Message 31 of 68
Re: Solid Broadband Connection but no Internet/Traffic
I disconnected my Sonos speakers and xbox yesterday
Will now try disconnecting Ring devices just in case
Message 32 of 68
Disconnect all devices and also turn off BT Web protect as that can also cause issues. That can be found by logging into my bt
Message 33 of 68
web protect is off
OK, everything disconnected, including laptop, but unfortunately no change. Solid connection, no internet.
Message 34 of 68
What happens if you use Google DNS?
Message 35 of 68
I set DNS on my Macbook to 8.8.8.8 and no change - still no internet pages will load
Message 36 of 68
Is the gateway set at 192.168.1.254
Message 37 of 68
Ok, can you help me on that one - gateway on the hub?
Message 38 of 68
Hub says
TCP/IP information
Default gateway:
172.16.16.230
Primary DNS:
81.139.57.100
Secondary DNS:
81.139.56.100
Message 39 of 68
What about the broadband IP address, that is missing from your list?
Message 40 of 68
The gateway on your devices should be set to your smarthub, which should be 192.168.1.254
