Message 1 of 7
True Key Premium Expired
I use True Key which comes free with BT Broadband.  Today I got a message that Premium has expired and I have 0 (zero) logins left.
I seem to remember this happening before.
Is this the same issue or has the BT MacAfee deal been dropped?
6 REPLIES 6
Message 2 of 7
Re: True Key Premium Expired
Hi @Navrig, sorry that you are getting this message when you use True Key.
Are you still getting this message today?
Cheers
John
Message 3 of 7
It is still happening on the Chrome Browser add-in but doesn't happen in the Android app.  I use the Chrome browser on two machines, one is Windows and the other a Chromebook.  Both show the same issue.
Message 4 of 7
@JohnC2 any more thoughts?
Tags (1)
Message 5 of 7
Hi @Navrig,
Thanks for getting back. I'm not sure if there is a lot we can do to help but I'll be happy to take a look for you. I'll drop you a private message now so you can get in touch.
Cheers
David
Message 6 of 7
It happened previously to several people on here and after being reported was fixed.
Maybe 12 or 4 months ago.
PM replied.  Thanks,
Message 7 of 7
The issue has gone away.  Not sure if there was intervention but if there was - thanks.
