Message 1 of 5
Request Return Bag
Hi, the contract is end on Thursday, where can I order return bag for BT hub?
4 REPLIES 4
Message 2 of 5
Re: Request Return Bag
normally return bag is sent when contract ends but you can phone CS 03301234150 and request one
Message 3 of 5
Hi @edmond1228 and welcome.
If you're closing the account a returns bag would be automatically be sent out but the CS guys will be able to confirm that for you. @imjolly has posted the number.
Cheers
David
Message 4 of 5
thanks for your reply. I received two return bags at the same time, Can I just use one of the return bag to return BT kits?
Do I need to return another return bag to BT?
Message 5 of 5
Hi @edmond1228  Just use one of the bags and dispose of the other one.
Neil
