Message 31 of 39
Re: Fibre 1 vs Fibre 2 - confused about advise from BT
@Anonymous
just use your address in the dslchecker as that will give you a result.  I have the same problem being broadband only
Anonymous
Not applicable
Message 32 of 39
I have, it isn’t accurate, states I should be hitting over 60Mbps download.
It also doesn’t show observed speed which the normal checker does.
Message 33 of 39
I have a few more questions…
Why is my observed speed different from the speed shown on Hub Manager?
The max download speeds appear to be the same 61 but the upload speeds are notably different – 19 vs 13.
When I test the speed using the BT APP I only get 51Mb Download 9.3 Mb Upload Speed to Hub - should I not expect to see 55 / 10 Mb speed to hub?
(Test was done using an iPad next to the router)
My maximum data rate according to smart-hub would be 13/61 if I upgrade to Fibre 2 is there any scenario where the max. speed could increase? Is it just the physical distance from the Exchange that impacts the speed and this is permanent, there is no scenario where this is improved?
Message 34 of 39
Ethernet has a 6% overhead so I would expect your actual data throughput to be 6% lower than the maximum shown line rate.  94% of 55Mb is around 51Mb so your measured speeds look right to me.
____________________________________________
BT FTTP 500/75 + pfSense + 4 x UniFi Wifi 6 Pro
Anonymous
Not applicable
Message 35 of 39
Latest update on me relating to this, the mods helped me get on the right profile and for the last month I have enjoyed the following:
New speedNew speed
Yesterday I ordered BT TV again to get the £10 BT Sport deal currently on offer (I know, I change my mind A LOT!), which also meant I re-contracted my broadband and of course I have woken up to 55/10 again:
Back to 55/10Back to 55/10
I have already reached out to @JohnC2 via PM to see if he can wave his magic wand again, but there is clearly some sort of parameter or setting in the background in BT systems that really wants me on a 55/10 profile no matter what product I actually pay for or my line is capable of! 🤣
Message 36 of 39
Hi @Anonymous, thanks for getting back in touch. The BT TV order has now closed and I've requested the profile to be corrected again. It should complete by close of play tomorrow. Please check and let me know it's been updated.
Cheers
John
Anonymous
Not applicable
Message 37 of 39
Will do, thanks @JohnC2
Anonymous
Not applicable
Message 38 of 39
Hi @JohnC2
This has gone through, thanks for your help!
Message 39 of 39
Hi @Anonymous, thanks for the update and glad it's back to normal now.
Cheers
John
