Message 1 of 3
Outage Question
Hello,
Im trying to find out some historical information on a broadband outage that impacted London in May 2022 - specifically I am trying to find out the duration of the outage.  Could someone help please?
2 REPLIES 2
Message 2 of 3
Re: Outage Question
@PH71
Assuming you are a BT Retail Broadband customer, you may be able to find the information by looking at your fault history, if that is possible.
If the outage was caused by a fault on the Openreach network, then they may be able to help.
Message 3 of 3
Re: Outage Question
Hi @PH71 and welcome to our community.
Did you register a fault or contact us during the outage? If so then there would be a record of that contact/fault on your account.
Cheers
David
