Message 1 of 2
Slow speeds
I was previously getting 60MB on a 67MB contract from NowTV.
I thought I would upgrade to 500MB fibre from BT. After having it installed yesterday. I'm only receiving 22MB connected by ethernet (all cat 8 cables used) and even less over WiFi.
The BT app says I'm getting my full speeds. But I'm clearly not. Any help before I tackle customer services would be Great.
tia
1 REPLY 1
Message 2 of 2
Re: Slow speeds
are you sure you are comparing like with like  MB megabytes and Mb megabits
if that is download speed with NOW than as 8 bits in byte you would need a faster speed than you currently have with BT
https://www.uswitch.com/broadband/guides/bits-and-bytes-explained/
