Message 11 of 15
Re: Speed seems stuck on a profile
The reason the try a filter in test socket is to eliminate a problem with the faceplate and you can also check faceplate is fitting securely as they can get dislodged
Message 12 of 15
Yeah, connected onto the test port, and I still get the same . Speed after test port.png
Message 13 of 15
DLM has banded your line at 35M
Message 14 of 15
you down speed keeps coming back at exactly the same speed suggesting stuck in a banded profile while you up speed appears stuck at fibre 1 max.  looks like you need openreach visit
Message 15 of 15
Ok, will contact CS at 150 then
