Message 1 of 5
banded profile
Can someone advise me whether I am in a Banded Profile, connection has been stable for more than 10 days was getting about 66 meg2022-04-18 (7).png
4 REPLIES 4
Message 2 of 5
Re: banded profile
Have you been having connection problems with hub dropping connection often or have you been manually resetting hub to try and improve connection or maybe combination of both?
Message 3 of 5
Re: banded profile
hello there thanks for getting back to me i turned it of a few times did not know that i was to keep it on
Message 4 of 5
Re: banded profile
A few manual resets in short space of time can be seen by DLM as an unstable line resulting in increase in noise margin and drop in connection speed. If you maintain a stable connection then DLM should start to reduce noise margin and increase in connection speed  however this could take a few weeks
Message 5 of 5
Re: banded profile
I will leave it on all ways now and see if it corrects it self in a few weeks. kind regards Phillip
