Message 1 of 10
Banded profile
Hi There,
I am wondering if someone can help. I upgraded to fibre 2 but I think I’m on a banded profile can someone help fix this?
Sam
Product code:Hub
Serial number:+091301+1926005829
Firmware version:v0.38.00.10147-BT
Firmware updated:Mon Apr 24 17:02:09 2023
Board version:R01
GUI version:1.77 20_05_2022
DSL uptime:6 days,07 Hours39 Mins20 Secs
Data rate:9.999 Mbps / 54.999 Mbps
Maximum data rate:16.931 Mbps / 56.386 Mbps
Full Fibre (FTTP) Mode:Off
Noise margin:11.0 / 4.0
Line attenuation:11.1 / 18.7
Signal attenuation:11.1 / 24.1
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:25.3 GB Uploaded / 191.8 GB Downloaded
Broadband username:[email protected]
Public Wi-fi status:Activated
2.4 GHz wireless network name:BT-Q3A65C
2.4 GHz wireless channel:Smart (Channel6)
5 GHz wireless network name:BT-Q3A65C
5 GHz wireless channel:Smart (Channel36)
Wireless security:WPA2
9 REPLIES 9
Message 2 of 10
Re: Banded profile
your not on a banded profile just looks like the upgrade to fibre 2 has not happened.  I doubt you are going to see any change in down speed as attainable is on 56mb but should see big improvement in up speed.
have you checked MYBT the you have been moved to fibre 2 - but not happened.
post back and most should be able to help
Message 3 of 10
Re: Banded profile
Hi, @samtheaspie I think @imjolly is on the mark with this and it looks like you're on the wrong profile. I'll send you a private message so you can contact the moderators and we'll be happy to help.
Neil
Message 4 of 10
Re: Banded profile
So out of curiosity how far away from the Openreach cabinet at you?  Looking at the SNR on the upload, if you are 600-700m away from the cabinet, these speeds might be as good as it's going to get!
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
Message 5 of 10
Re: Banded profile
@Crimliar when we were with sky we got 66meg on the line sync speed. But for some reason BT are being unhelpful and saying we can only have fibre 1 speeds when we have fibre 2 package.
@NeilO i got your message I’ll reply when I’m back home thank you
Message 6 of 10
Re: Banded profile
I don't know if this is relevant, but if you are not right on top of the cabinet,  you'll see the maximum theoretical phy rates, but getting either one of those may depend on the other being "sub-optimal".  So rather than getting those theoretical maximums, the actual link rates are compromised.  What gets complicated is that different equipment will negotiate different compromises.  So historically if I used a Huawei HG612 V3 modem I'd get better upload speeds but worse download speeds than the Dratek modem.  Using the SNR adjustment feature on the Draytek also allowed a degree of customising  - lowering the SNR margin increased download speeds at the cost of decreasing upload speeds!
Message 7 of 10
Re: Banded profile
Hi @samtheaspie, would you check and see if your profile has been updated and post back to let me know.
Cheers
John
Message 8 of 10
Re: Banded profile
@JohnC2 All changed mate. Not the jump in speeds I was expecting but at least we are on the right profile so thanks for your help! That was from last night I got my partner to send me a screenshot
Message 9 of 10
Re: Banded profile
looking better now but as expected little movement in down speed but big jump in upspeed
Message 10 of 10
Re: Banded profile
Hi @samtheaspie, thanks for checking that and posting back to let us know the profile has been corrected.
Cheers
John
