Message 31 of 49
Re: much slower quoted speed than neighbours - cabinet full ?
This is the technical log. Not sure what this means. Appreciate any insight.
Looking for similar posts, is it a DLM banding issue? (Not even sure what that means).
We have an old British telecom grey box on our outside wall, with a wire coming indoors into master socket. Hub is linked directly into master socket (a fairly old one with single plug). The master socket also has 2 wires going to other rooms which may be causing a bridge tap within the property perhaps?
Anonymous
Not applicable
Message 32 of 49
Well the first screen shot you posted said you're on on VDSL & the DSL checker reckoned that around 30Mb. But that also said FTTC was unavailable so a bit confused. But then the upload speed of nearly 2.9Mb is higher than anything ADSL can manage IIRC.
I think I'd be inclined to remove the faceplate of the master socket & see if there's test socket behind it. Plugging directly into that should remove any internal wiring from the equation.
Message 33 of 49
Yes its a good ADSL but a bad VDSL.  There is no socket behind the master socket, but it is old, so maybe the engineer will change it.
Any comments from anyone else will be helpful. Otherwise shall update after the engineer visit.
Anonymous
Not applicable
Message 34 of 49
If it's that old it may well still have the bell/ring wiring. But probably best to leave for the visit tomorrow.
Message 35 of 49
Message 36 of 49
G993_2 is VDSL
Message 37 of 49
I suspect you have a line fault where 1 wire of your pair is disconnected. If you had an analogue phone service you would be able to check as you wouldn't get dial tone.
Message 38 of 49
Oh thanks for the insight. We haven't connected a phone to it (will have to dig one out). It's a sogea VoIP number so I was wondering how to connect a phone in the first place. Is the fault likely to be in home wiring/socket or at the exchange?
Message 39 of 49
It could be anywhere if that is the cause of the problem.
Presumably you have a third party VoIP service as SOGEA doesn't have a telephony capability. In any case, it won't prove anything, it is only an analogue service that won't work with one wire disconnected.
Message 40 of 49
I do have digital phone service from BT, they included a phone number when the home move service went active.  But I can't figure out where to connect the phone...
