Message 31 of 47
Re: My BT App Not Working
Have you tried reporting the problem to the developers on the relevant app store.
Message 32 of 47
Re: Mobile usage on app
Hi @Videtta5 I'm sorry, it's a known issue that's being worked on. I'm sorry for any inconvenience caused.
Neil
Message 33 of 47
Data useage
Why can I no longer see my mobile data usage on the mybt app?
This lack of information is causing me problems balancing my use whilst on holiday.
Message 34 of 47
Re: Data useage
iOS My BT update saying bug fixes……no still not working.
Ver 8.50.2
Message 35 of 47
But why is the fix taking so long, it's been around 2 weeks now?
Message 36 of 47
All this update seems to have done is replace the meter on the ‘front page’ with a link to the usage section….. which for me contains incorrect data.
If I go into manage my products / mobile on the web I get a completely different usage figure to the one the app is now pointing us too.
Message 37 of 47
Just looked now - the page the app takes you to shows 6.4GB of my allowance remaining when the product management page shows (correctly) 1.76GB left.
Plus the app continues to not sign you in to view information meaning you have to continuously enter your My BT credentials, which is made even more infuriating as the login page is not recognised by my iPhones password manager so I cannot autofill and have to laboriously type out my email address every time 😡
Frankly it is more trouble to use the app than the webpage.
Message 38 of 47
For me the Web page is showing no data used when I know I have used quite a bit listening to radio and downloading from Netflix. It will be interesting to see what happens if I go over my allowance
Message 39 of 47
Is there there an update please @NeilO
Message 40 of 47
Any update on this please?
