Message 1 of 4
Cannot access MyBT
Hi,
I cannot access MyBT anymore. After a login attempt, it takes me to the login page again with a "Something went wrong" message. If I try to be sent new credentials, it sends me back to the same "Forgot login details" without any other feedback (errors or anything).
Can you please advise?
3 REPLIES 3
Message 2 of 4
Re: Cannot access MyBT
seems I am not alone with this....
my post:
https://community.bt.com/t5/Bills-Packages/No-longer-able-to-log-into-MYBT-on-any-web-browser-but-ca...
are you able to log in using the phone app, like I can ?
Message 3 of 4
Nope. It says "We are having a technical issue".
Message 4 of 4
It magically started working again.
