Message 1 of 3
Claiming Reward card blank
Good morning,
I have what appears to be the common issue of not being able to claim a reward card as it appears blank. I believe this is due to having old accounts from what I’ve read.
I’m hoping a BT moderator can help 😊
2 REPLIES 2
Message 2 of 3
Re: Claiming Reward card blank
Hi @lukey_79 and welcome to our community.
Thanks for posting about the reward card. Sorry you're having problems claiming it. I can help. I'll need a few details so check your inbox for my message and drop me over the details.
Cheers
David
Message 3 of 3
Thanks for sending over the details @lukey_79 .
That's been processed for you now and will be with you after the orders close off.
Cheers
David
