Message 11 of 16
Re: No Final Bill
Hi @nedjohn, thanks for getting in touch. I've checked and the final bill will be issued later today.
Cheers
John
Message 12 of 16
Re: No Final Bill
@JohnC2 thank you for the update.
All, if reading this as you are leaving BT yourself, or via a new Supplier, and looking to avoid bad credit records and court actions: Ideally, drop your BT Mail if you can when asked, as it complicates your exit (requires a new account setting up and a migration).  Once you have your end date or cut-over, keep a check on MyBT ‘Your Products’ to see they go grey on the date.  Start chasing if not.
If searching due to a missing Final Bill  problem 7 days after cut-over or exit - my solution, having tried various calls/chats/complaints:-
The best method to get to a knowledgeable person who may know enough to fix it: web-chat Account & Billing.
The best method to get attention for oversight in BT: raise a Customer Complaint about Billing, that you are receiving Recurring Bills for services you have no longer Contracted for, in contravention of your Consumer Rights.  Until you get your Final Bill the Complaint is not resolved for you (BT Staff will likely see an explanation for the delay as sufficient resolution), so check regularly that the Complaint hasn’t been closed and reopen it when it has been.
Message 13 of 16
Re: No Final Bill
Finally received my Final Bill.
Overcharged by 3 days - the 3 days I spent chasing BT to close down the service after it was scheduled to happen.
Sorry to be going but now glad to see the back of BT.
Such events are thankfully rare (or not), so don't have nightmares.
Message 14 of 16
Re: No Final Bill
Hi @nedjohn,
I am so sorry that you were charged for those days. I reopened the complaint and added a credit of £5.39 to offset those charges as you shouldn't have been charged. I hope that you are ok with that.
Thank you
DanielS
Message 15 of 16
Re: No Final Bill
@DanielS
thank you Daniel for your intervention.
I was content to pay for 2 days, due to Recurring Billing date - I already had.
Charging for the subsequent 3 did seem a bit much, so I appreciate your intervention.
Message 16 of 16
Re: No Final Bill
You are more than welcome @nedjohn.
A promise is a promise so I didn't want to let you down.
Feel free to post up here any time.
DanielS
