Message 11 of 16
Re: No Internet for almost a month. How to escalate an issue?
Hi @alan325e90 and thanks for confirming that.
Your best bet would be to contact the FTTP guys on 08005874787 (thanks @imjolly). This might be an ONT mismatch but if you can provide the serial number they'll be able to cross reference. Let us know how you get on.
Cheers
David
Message 12 of 16
I called FTTP and they have confirmed the ONT serial number is matched.
Message 13 of 16
Thanks for confirming that @alan325e90 .
Were they able to advise what the issue might be? Did they run any tests etc?
Cheers
David
Message 14 of 16
They said my line is still not activated. Need to pass to another team in BT to follow-up the activation which will take another 5 working days. But it is the third or fourth time I was told to wait 5 working days.
Message 15 of 16
Thanks for the reply @alan325e90 .
I'm sorry there's been continued delays with the order. I can try and find out what's happening if you like. Check your inbox for my message and drop me a reply with the details.
Cheers
David
Message 16 of 16
@DavidM  Thank you so much for your help.
