Message 11 of 30
Re: Quidco Cashback Declined
Yes it was DavidM. I had already raised a claim which was declined before I posted here.
There is no way to raise another claim on Quidco as you can only do it once.
Message 12 of 30
All I can suggest is to wait for another reply here. What date is your service supposed to be activated, as you have up to 14 days after that to cancel? You may have to wait a long time to get service from another provider, as its a busy time of the year for Openreach.
The BT Promotions Team should be able to raise the issue with Quidco, if there was an issue with the order. A forum search shows this thread https://community.bt.com/t5/Bills-Packages/Quidco-cashback/m-p/1925028
There are other threads as well.
https://community.bt.com/t5/forums/searchpage/tab/message?advanced=false&allow_punctuation=false&q=q...
Message 13 of 30
Thanks. Let’s hope they reply and can resolve it one way or another.
Message 14 of 30
Blocked Duct
So I thought all was on track to move to FF 500mb however when the engineer (OpenReach) visited they were unable to pull the cable from the manhole in our complex, maybe 10m away, to my unit.  They came back with some equipment and were able to identify a position where they believe the duct is compressed/crushed.  They asked for authority to dig to repair the duct which they have and the engineer who visited said is acceptable.
The issue I have now is I have no idea or visibility of when the "dig team" will pick up the job and visit to resolve.  The engineer has been very helpful but says it is out of his hands now and he cannot advise when it will happen.  Is there any advice or contact numbers anyone can suggest for me to identify when this part will be scheduled and completed ?  I was originally due to move providers on Thursday !
Message 15 of 30
Re: Blocked Duct
If you call up the FTTP team in BT Consumer they will be able to look at the status of the order with Openreach and request further updates.
0800 587 4787
Message 16 of 30
Re: Blocked Duct
Thanks @jac_95
I presume the order number I have for my BT order will be enough to have the discussion.
Message 17 of 30
Re: Blocked Duct
If you are the BT Consumer account holder then they will be able to discuss it with you.
Message 18 of 30
Re: Blocked Duct
Hi @Kssquared1 and thanks for posting.
You've mentioned the connection is in a complex and for a 'unit'. Is this for a business?
Cheers
David
Message 19 of 30
Re: Blocked Duct
Nope it’s residential.
I got a text this evening from BT now pushing the date out to February !! Any suggestions on how I could improve this ?
Message 20 of 30
Re: Blocked Duct
Have you called the FTTP team yet? The february date is maybe just a place holder so the order doesn't close but the FTTP team would be best to advise
