Message 1 of 3
Re BT returns
I have received a bag to return a home hub5. As you can see in the photo there is the return address label and a seperate bar code sticker on the left. My question is "does this bar code sticker go on the return bag as well as the address label?"
2 REPLIES 2
Message 2 of 3
Re: Re BT returns
Hi @arbeeuk, thanks for your post and sorry for any confusion.
The barcode at the side has a note, 'lift here to return', if you lift this off does it say anything underneath?
Either way as long as you get a proof of postage and keep this until the item is marked as received back it should be ok with just the address label.
Cheers
John
Message 3 of 3
Re: Re BT returns
Thanks John.
There is nothing under the lift it here label so I will just use the address label like you suggested.
Thanks again.
